daveengstrand wrote:
To be fair, movement from driving down the road can obviously play a part.
This is the most important part of this post.
That will have minimal effect on PEX tho.
There may technically be minimal effect on PEX, but the CONNECTIONS on the PEX are as susceptible to movement and jarring as any other connection.
There is absolutely no correlation between the risk of water leaks in a S&B house and the risk of water leaks in an RV. (Unless you want to talk about the risk of water leaks in a S&B house after a major earthquake, and I warrant that those risks are VERY high.)
