path1
Sep 17, 2015Explorer
LarryJM wrote:path1 wrote:GENECOP wrote:
I can reach mine....laying under the slide....
Sorry, I meant the gasket under the slide out AWNING.
Here is what I use soaked in 303 and about the same as you are doing, but this is much more compact, easy to use and convenient to store. I also use the single section with the rag as a way to clean and lubricate the slide seals between the seals and the slide surfaces where my hand with a rag is hard to get between because of clearances. The rag holder for shotguns is a great size for the rag holder for the slide seals. I used what I had and simple used a very long strip of cloth wrapped around and tied to form the "swab".
Larry
Very good idea.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
