wizards8507
Oct 18, 2017Explorer
Mortimer Brewster wrote:
I found this on a Dodge dealer’s website
Best-in-Class Towing
When equipped with the proper equipment, the 2016 Dodge Grand Caravan is able to get a best-in-class towing capacity of 3,600 pounds. The available towing package is called the Trailer Tow Group, and includes a Class II receiver hitch, a load-leveling and height-control suspension, and the average four-pin connector wiring harness for the trailer.
If your Grand Caravan has the Trailer Tow Group as an option, then the towing capacity would be 3600 lbs. A GC without it would be limited to 2000 lbs.
FYI, any trailer with electric brakes will need a brake controller to activate the brakes. You will need to check into this.
FWIW, I towed a popup with a Grand Caravan about 15 years ago. The GC did okay in the flatlands, but strained in the mountains. I recall being concerned about wear and tear on the brakes and transmission.
Hope this helps. Keep asking questions!
That information is incorrect (or misleading at least). I linked the dealer brochure for the 2016 GC below. The Trailer Tow Group is only an option on the R/T trim, but it doesn't actually do anything to increase towing capacity. It's essentially a sales gimmick. The AVP, SE, SE Plus, SXT, and SXT Plus trims are all rated at 3,600 lbs and the Trailer Tow Group is not even an option for them (see page 21 of the PDF below). The equipment I had installed at the dealer is "better" than the Trailer Tow Group anyways. It's a Class III hitch and a seven-pin connector.
https://cdn.dealereprocess.net/cdn/brochures/dodge/2016-grandcaravan.pdf
troubledwaters wrote:
So the manual that was written by the Engineers that built the GC tell you what you need to use to tow with it; and you come here for what? Confirmation that you don't really need to follow the manual? Fine by me, don't use one, it's not my car.
No, that's not what I'm saying. And frankly, people like you are what keep people like me from entering the world of RV camping in the first place. Know-it-alls, usually with giant rigs and F-350s, who piss on people trying to learn from those with more experience.
Everything I'm looking to do is 100% in compliance with the manual. The only place I've seen the weight distribution equipment mentioned is on the MoPar product description of the hitch I have installed. It has nothing to do with the vehicle itself.
P.S. I've never heard of properly sized and adjusted weight distribution bars damaging a trailer. Where did you come by that information?
See Ralph Cramden's post above.
Earl E wrote:
You can try it without the weight distribution hitch and see how the Caravan rides. The problem is the Caravan has such a soft suspension that it will take very little weight to make the car's tail end almost drag the ground. The weight distribution hitch will transfer some of that weight to the front axle.
Is it possible that your information is outdated and things have changed with newer-model GCs? I weigh more than what the tongue weight of my trailer will be and when I jump up and down on the bumper, the suspension barely moves an inch.
About RV Newbies
