wizards8507
Oct 18, 2017Explorer
Mortimer Brewster wrote:
My previous post described the factory tow package. Besides the receiver and 4 pin harness, it has a load leveling and height control suspension. This suspension is doing, or at least attempting to do the work that a WD hitch would normally do. In other words, a Grand Caravan with the tow package does not need a WD hitch.
So when the MoPar hitch receiver says "3,800-lb tow rating with weight distributing equipment, otherwise 2,000-lb tow rating," you're saying the load leveling and height control suspension in the tow package fulfills the need for "weight distributing equipment"?
The OP needs to check if his Grand Caravan has the factory tow package (check with a dealer if unsure)
I do. If my understanding above is correct, I'm all set.
and if he will need a brake controller for the trailer that’s under consideration.
I do. I'm wired for it, I just need the controller itself. Recommended at 1,000 lbs and required at 2,000.
About RV Newbies
