RinconVTR
Nov 12, 2017Explorer
Pool lines are 1-1/2 or 2" Easy to blow out with high volume and low pressure.
Water lines not so much.
If you're looking at using air, you do in fact need an air compressor pushing anywhere from 20-60psi to really blow the lines.
I blow mine out multiple times after Fall weekend stays...then in Nov pump anti-freeze thru and into the drains for the consistent cold and zero-use period.
About RV Newbies
