lordnorth
Nov 13, 2017Explorer
valhalla360 wrote:
For blowing out lines, volume not pressure is the primary consideration.
As long as the 6PSI can overcome the head enough to get the water starting to move out of the fixtures, it should work fine.
Thanks... that's what I thought too.
I tried it this morning and at first I got a really good slug of water out of each of the faucets. Then I got blowing and mist -- Good signs.
But then I got to where the pipes just sort of gurgled -- Not a lot, but enough to know that there was still some moisture in there.
Going to try to modify my connections and I did forget to isolate my water heater. See if I make out any better this afternoon and can avoid buying a compressor.
About RV Newbies
