mgirardo
Nov 13, 2017Explorer
I think the 6 PSI will get the bulk of the water out, but I don't think it will get all of it out. After the bulk of the water is gone, 6 PSI won't be able to push out what remains. I usually blow out our lines with 35 - 40 PSI. On our 42' TT, it takes about 6 minutes to get the bulk of the water out, then another 5 or so minutes of it misting before only air comes out.
What is causing the gurgling will be enough to cause a fix to crack. If you plan to use RV Anti-freeze, then I wouldn't worry about it, the anti-freeze will push the water out. If you aren't using anti-freeze, it will be a problem.
-Michael
-Michael
About RV Newbies
