Greenhorn here. Yesterday I turned down buying an RV at a great price because it had a small amount of de-lamination on the driver side rear. It was clear that the roof had been recently repaired, s...
If you see a little damage, that means there is more damage that you can't see. If the roof was leaking, and the water damage you see is at the bottom, then there is wet stuff inside the wall. It is ALWAYS worse than it looks.
