waldreps wrote:
Thanks for all the suggestions. I'm not trying to be rude but I can't afford a generator as quiet as some of you are demanding. I'm sorry that I'm not rich enough to camp next to you. For the trip I'm going on, it's a music festival and not a campground so that's why I'm not too concerned about the noise. Most other people there use the same type of generators that I'm looking at and nobody cares. If I'm the most hated person in the campground cause I can't afford a super expensive quiet generator then it's probably not a campground I would want to camp at. I'm really not trying to be a jerk. I just don't like getting repeatedly jumped on cause I can't afford the top of the line equipment. I think people should be a little more forgiving and stop hating people cause their generator is a little louder cause they couldn't afford the expensive ones. What's next... Is my camper too old or is the paint too faded to park next to you? It's fine to be considerate of others and I try to to the best of my ability, but spending 3 times as much just so I don't upset you with a little more noise seems ridiculous. I'm researching and buying the best deal and quietest one I can afford. That's the best I can do. I'm sorry.
It's not a matter of just "generator snobishness". The well meaning folks that have the inverter generators are suggesting you get an inverter model because they are the choice of those who camp close to each other or at National Park and State Parks where the noisier open-frame gensets are outlawed. You also won't find many private campgrounds that allow their use. Did you see the post where the guy was in three altercations because he was using an open-frame genset? Unfortunately, this is what you can expect, someone close by will be complaining and asking you to turn it off. If you're just going to the back of the woods or the end of the trail, sure, use the open-frame unit. When you get tired of the roar, think of what was mentioned here or take a look at solar. Solar will run everything except a roof top AC.
