Geocachers924
Jul 04, 2015Explorer
DEF tank
New owner of a 2016 Navion 24G and was wondering if this RV has a DEF tank and how often it needs to be filled and where the input tube is located on the vehicle? Thanks. Terry
C-Bears wrote:Old-Biscuit wrote:C-Bears wrote:
Doesn't that have a Mercedes diesel engine? I would hope that they would have located the DEF filler next to the fuel filler cap. Having it under the hood is not going to be very convenient.
Having it under hood is a good thing.
Folks that have it inside the same compartment as fuel filler have made the mistake of putting DEF into diesel fuel tank. OR putting diesel into DEF tank. Check out some FORD 6.7 DEF/Diesel Issues
DEF is WATER & Urea. BIG $$$ damage can occur to fuel pump, fuel lines, injectors
Diesel into DEF tank.......can destroy the SCR catalyst.
Having DEF filler under hood is a good thing.
I guess that could be possible (as the saying goes....can't fix stupid). I think it would be hard to get a diesel nozzle into a 1" DEF inlet. If you were dumb enough to be doing that it seems you would immediately realize something wasn't right when diesel was spewing all over the place.
As far as putting DEF into a inlet clearly marked "DIESEL", well what can I say.....
