I_am_still_wayn
Oct 07, 2013Explorer
The "fireplace" has to be rated not to transfer heat to anything behind it, otherwise a serious fire hazard would exist. If you look at the specs for that "fireplace" you will find that it probably has a zero tolerance specification for placement against anything at the rear. It is designed to transfer all heat to the front. The television should be OK.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
