kVox42's avatar
kVox42
Dry weight dilemma ... from my vehicle manufacturer
First, I'm new to this whole process, but plan to take an extended road trip later this year. I will be traveling solo and I'm perfectly comfortable with minimal amenities. With that said, here's (one of) the early questions I've run into, and I can't get a definitive answer to a VERY IMPORTANT question.
I have a 2010 Golf TDI-standard transmission, which is a fuel-injected turbo diesel. It has lots of torque and plenty of power (as compared to a straight gas model).
I’m looking at small, light-weight camping trailers now available and have come across conflicting information.
My owners manual says the vehicle is rated to tow up to 1,000 lbs.
However, in Europe, (including the UK), the same car is rated up to 725 kilograms - which is 1600 lbs, obviously a significant difference (60%) I’ve also come across reviews, articles and forum posts that list TDI models as being the best towing vehicle for its size in the UK. So my question is ... what explains the difference. I have written (and called) VW-USA and although they're friendly enough, all they will say is that "there's a difference in the 2 vehicles". When I ask for specifics I get basically corporate stonewalling.
I have no desire or intention of “maxing out” what I will tow. In fact, I'm focused on keeping the trailer as light as possible. However, the 60% difference is confusing. Does anyone know if there IS a difference between the European and USA versions of the vehicle? If so, what exactly is it?
Horsepower?
Engine size (displacement)?
Breaking system?
Suspension?
Is it an emissions issue?
Bottom line is, all I'm trying to find out is can my US golf pull up to 1000 or up to 1600 pounds?
Kevin
Raleigh, NC
  • You state that you have a manual transmission. The weak link there will be the clutch.
    Do the European models use a different transaxle assembly with possibly a more heavy duty or larger clutch ?
    As someone already stated, are the European and USA engines rated at the same HP ? They very well might not be due to different emissions requirements.
    You're going to have to be careful of that clutch when you maneuver in tight places (campgrounds), going back and forth between 1st and reverse when getting into campsites. It was never designed for that.
    Tim
