bid_time wrote:
Rapidly Dump a 5 gal bucket of water down the toilet after emptying the tank and you'll flush all the clumps out. Spraying up the open dump valve is just plain nasty. Not to mention the mess you're making around the dump station site.
You don't have to tell me it's nasty... I know that first hand.
I don't make a mess around the dump station as I hold the hose right up under the drain pipe so it all goes in the hose. If any does inadvertantly go on the ground, I clean it by spraying it down the dump station.
