Harvey51's avatar
Harvey51
Dumped slinky recovery
The very first time I dumped, the slippery slinky slipped off its fitting attached to the RV and ran into the hole at amazing speed. It happened again this week, 4 years later. What an embarrassing newbie moment! Luckily I was not in a busy dump site either time. There was great temptation to slink away and leave the darn thing in the hole but responsibility won out.
The first time, I went looking for a long piece of wire to fish the slinky out of the hole. Meanwhile DW found a tree branch with a hook-like broken off branch on the bottom and used it to hook the slinky and pull it out before I got back with the wire. Yet another reason to get married.
This time I did try fishing with a light wire and had poor luck so I used the branch trick again and had no trouble. The stiffness of the branch ensures success. I am interested in how others do it, if any of you have been as careless as me about maintaining the clamp on the slinky end. I intend to carry five feet of heavy wire from now on in case there are no tree branches handy next time.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I too use a 90 degree fitting with either a "Yummy sewer donut" or a threaded coupler, This is the proper way to do it as it seals the hole so no sewer gasses escape. the old hose in the hole is not recommeneded and in some areas may be prohibited.
    As for the awning hook, Also known as the RVer's friend.. No, I'd not be amazed at all.. I have used mine for many many uses including pulling the jack pads out from under the RV. and the leveling steps. and the sewer hose out of the storage pipe and ... Well about the only thing I have NOT used it for is pulling the awning out since it's a power awning.
  • You would be surprised how many uses I have found for the awning pull down wand :B
  • I use the macerator and don't worry about messing with the stinky slinky....thanks for sharing your humor though!.....Dennis
  • I always use a 90 degree fitting on my sewer hose. One reason is that it provides a nice, tight connection (no worries about the hose getting loose and spraying the ground with waste) at places that have a screw-on dumpsite. Second, at places where it needs a weight, it is easier to keep the fitting in place than just the hose. Finally the fitting keeps the hose out of the hole, eliminating any chance of losing control of the hose. If it gets disconnected from the RV, it falls to the ground, and that's it.
  • Reach with your hand and pull it out. Hands are washable. If uncertain about how to do that, you should be wearing rubber gloves for any dumping or slinky handling.
  • do you not have a fitting on your rv that it clips on? Im new to this and only dumped mine once but you put it on and turn it and it locks on tight, I dont see how it would ever fall off accidentally, lol!
