scottz
Jul 13, 2013Explorer
Hole******folks! (pun intended) No need to flush anything as long as you have 12 gallons or more in the gray tank! It is always good practice to dump with mostly filled tanks anyways.
1. Connect drain hose
2. Pull Black Lever (wait until it stops)
3. Push Black lever
4. Pull Gray Lever (wait until it stops)
5. Push Gray lever
6. Disconnect drain hose and put away.
Drive away
Takes 5 minutes.
3. Push Black lever
5. Push Gray lever
Drive away
Takes 5 minutes.
About RV Newbies
