A little more on "blow down" winterizing; don't operate the "water heater by-pass valve" it's only there so you don't pump antifreeze into the heater tank. I let the air compressor build volume in the hot water tank while I'm doing other things, like removing the water filters and aerators. Then when I open each valve one at a time until I have nothing but air coming out. Don't worry about setting the pressure low. It's a standard plumbing system designed to operate at 150PSI (the water heater safety valve is set to relive at 125PSI).
The reason I use a lot of antifreeze in the holding tanks is because I use my RV during the cold weather. I want to make sure I have good delusion of any residual water that may be left in tanks and the dump-valves will operate. Otherwise I'd just a quart or so and not worry about it.
There is another reason for not pumping antifreeze into water lines besides the taste: Propylene Glycol breakdown EDPM, that's the faucet washers, "O" rings, diaphragms and seals. That statement on the bottle that says "Safe of all plumbing"... you need to read a little further, there is a disclaimer about prolong exposure to EDPM.
