Sunset_Gypsies's avatar
Feb 02, 2020
Electric blanket and inverter
Found an electric blanket that the inverter does not fry.
SoftHeat by Perfect Fit | Luxury Low-Voltage Electric Heated Blanket
The control and blanket run on 18 volt DC, separate power supply feeds the control from 120 vac. Works fine with voltage from a modified sine wave inverter.
Could probably replace the power supply with a 12 to 18 volt DC to DC converter to save energy.
