Old-Biscuit
Dec 02, 2015Explorer III
forhumanservices wrote:
yes moves with no pressure....what is involved in removing the cover?
If I had to do it manually, is that even possible?
Thanks a ton!
Just pop the top cover off......it is just snap fit
If it moves OK without pressure then it sounds like a stripped gear/broken tooth
Manually.....that is what crank handle and hole in side of 5vr is for.
Takes lots of turning BUT it won't help in this situation. Manual is for when motor quits
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
