WA4HTZ
Jul 28, 2017Explorer
You need to check everything in the 5er which is AC powered. You said the microwave and the fridge were dead. Is the fridge an RV gas/electric or a residential type? If its an RV fridge a low "strength" (voltage) event should not have harmed it. Be sure to check the TV, both A/Cs, and the converter. Use a volt meter on the battery, not the little indicator lights that show "Full", two-thirds, etc. They aren't very accurate. Connected to shore power, it should read above 13 volts. This almost sounds like a high voltage event, not a low one and means everything which runs on AC and anything which was plugged into an outlet may be damaged. Make a list for your insurance company of what doesn't work.
Good luck and I hope you get everything fixed or replaced and you can continue to enjoy camping.
Ken
Ken
About RV Newbies
