wa8yxm
Jul 08, 2017Explorer III
The "Kit" I have is 5-30 amp.. THat generally covers it, however there is more.
Auto manufacturers are not content with a single fuse so there is ATC, and ATX and Maxi fuses on this RV,, So I need 3 kits (Well on the Maxi's I only carry a couple)
Basically if yours is a trailer, find the fuses and see what sizes they are, Likely ATC (Physical size) and 5-30 amp but anything is possible. I have fuses up to 40 amps here but only on one circuit and it can get by with 30's since the draw on that line is less than 10 (It's a power distribution panel).
You may find you only have 20's in that power panel... In which case get just that size. (I have 4 power panels plus the power strip in this RV, fuses of all sorts of sizes).
About RV Newbies
