jefe_4x4's avatar
jefe_4x4
This is embarrassing: Magnatek failure?
I dismounted the camper from the truck at the end of Spring and lowered it onto my storage jacks for the summer. We had a round of friends visiting, 7 in all, so Jeanie and I slept in the camper a few nights when every bed was taken in the house.
I usually keep a minder on the battery but this time I put a 2amp tapering charger on the battery. The battery showed 12.8 v.
To the question: Does the TC to truck pigtail need to be plugged in to make the TC systems work?
I've never stayed in the camper, off-truck, so have no experience.
The problem is I have no circuits. No juice is getting to the panel. I plugged in the 30amp plug into house current: Nothing. No electrical appliances work inside or outside the camper. I checked the 2 breakers on the panel: all in on position. I checked each individual fuse: all good. I usually hear a hum when I plug in the AC 30amp umbilical. No hum.
I suspect it's the Magnatek 6325 that came with the Lance in 1998. I"ve never had a problem with it, and we have minimal electrical needs on board, but i read that they are a cheap item prone to overheating.
I did a search and found there are some amazing electrical geniuses on the TC forum. I am not one of them. If you are one of them, I could use a little help here.
regards, as always, jefe
