navegator
Mar 07, 2015Explorer
If the extend a stay or stay a wile, or what ever you use and it is installed between the RV tank and the regulator, the regulator needs to be supported with a bracket, otherwise the extended weight of the the 2 units will brake at the tank with the vibration of the RV on the road.
I have the extend a stay hooked between the tank and the regulator supported with a home made bracket, this allows me to hook a 5 gallon tank, and use that for the water heater, stove, cabin heater it is easier to take a small tank to be filled rather than moving the entire rig when staying at a far out of the way camp ground
I have installed a quick connect for the BBQ teed of from the stoves line at the rear of the rig.
navegator
navegator
About RV Newbies
