newbie_canuck's avatar
Jul 04, 2018
f150 supercab short box
hi; new to 5th wheeling. bought 26 ft. triple e and having receiver installed today on f150 short box. I know i need a sidewinder extension but my issue is i need to pickup trailer and get it to hitch guys to install it. Can this be done. carefully. without sidewinder?
  • You will someday be amazed at how much more comfortable the ride is in a long-bed, crew cab.
    Wheelbase length counts.
    (Don't ask about turning circle!)
  • nickthehunter wrote:
    You people don’t know the weight of his 5er or the ratings on his truck and your already pAssing judgement. Why don’t you just Answer the question asked or keep quit until you know what you are talking about (translation: facts not guesses).
    That was my first thought...just answer the question!!
    That guy didn't ask any questions about the truck's capabilities in towing the trailer...that is so annoying.
  • You people don’t know the weight of his 5er or the ratings on his truck and your already pAssing judgement. Why don’t you just Answer the question asked or keep quit until you know what you are talking about (translation: facts not guesses).
  • JaxDad's avatar
    JaxDad
    Explorer III
    If it's anything like my friends unit it's about 8,000 pounds empty.
    Unless you've got a 5 liter truck with a deep rear end ratio you're going to be pretty overloaded.
  • And does "new to 5th wheeling" mean new to towing or just 5vers?
    Donno has a point in that different peeps have differnet skills, abilities and comfort levels and a bigger truck than what you have IS the "safer" answer if you're totally inexperienced with this.
    Also intended use and duty cycle come into play, I'd suggest doing some reading first if you have questions. You didn't post much info to chew over and "F150" could mean base model NA 6 banger work truck, Raptor, or it could mean Eco boost max tow max payload, etc etc. totally differnet capabilities.
  • Or if you aren't into buying a new truck, if your pin weight is reasonable as is the trailer weight (no idear what a 26' triple e is...) then there's no reason the truck can't be capable of pulling it, save for when you say short bed, do you mean short short or medium short?
    I'd be cautious of the 5.5 bed and actually being able to get the pin over the axle at all.
  • There is no way I would consider doing this. Trade the truck for a 250/2500 and move on.
  • Have you asked hitch guys to transport the new 5er?
