MudChucker
Jul 19, 2016Explorer
filling the fresh tank with it is no big deal, you can run some water through to flush it out before you fill.
the trouble with the typical garden hose is when you use it for your "city water" hook up, the hose sits in the sun filled with water and leaches chemicals from the hose while you are out of the RV all day... when you return and turn on a tap the water will be loaded full of man boob causing BPA for example.
About RV Newbies
