myredracer
Sep 13, 2016Explorer II
Walaby wrote:SpeakEasy wrote:
They'll also have the pressure regulators. These just screw onto the female end of the hose and onto the campground's water spigot. Just don't forget about it and leave it attached to the spigot when you move out.
-Speak
I actually connected my regulator to the city inlet connection (vice the campground spigot). That way I know I will never forget my regulator.
Mike
Except if the CG pressure gets too high it's possible to blow your hose. I've seen as high as 140 psi so far at a CG. High pressure hoses are available. We use a Valterra hose rated for 160 psi (our reg. is inside).
On the black tank, it helps to put in 3-5 gallons of water before you use the toilet to avoid a pyramid of p**p buildup that can block the inlet pipe.
About RV Newbies
