Control_Freak
May 29, 2019Explorer
First RV
My spouse and I are looking at purchasing our first RV, he grew up camping, I did not.... We have a 2019 Chevy Silverado 6.2L with max trailering, manufacturers tow rating of 12,200 pounds and are ...
Jebby14 wrote:
No, frankly im saying you don't have enough truck. not even close. I ran your numbers through to figure out what payload your truck can comfortably handle. ONLY payload considered here since with a half ton its usually the limiting factor. As I suspected you don't have enough. PS if 100 lbs of hitch throws a wrench in things then IMO not nearly enough margin.
remember dry weight is not the weight of the trailer before you load it. dry weight is without things that are in it when you get it. IE propane tanks, batteries, appliances,
Do what you want, I wouldn't dream of pulling anything close to that big and heavy with that truck. good luck.
