temccarthy1
Oct 26, 2017Explorer
rvshrinker wrote:
Supplying my new TT.
This is what I have on my list:
Water inlet hose
Water pressure regulator
Upgraded sewer/black line
RV level
Leveling block set
Wheel chocks
Jack cap/block
RV toilet paper
RV toilet cleaner
Black tank/toilet chemicals
Grey tank deodrizer/chemical
Scissor jack socket drill adapter
Anything else I need that is RV specific (obviously not talking about things like towels, plates, hand soap, etc).
These are all reasonable except do not need the RV toilet cleaner and grey tank stabilizer. Make sure you buy screens to fit your outside vents IE: furnace vent, water heater vent and fridge vent. You can get on Amazon under $10 each and will prevent mice, mud wasps and other insects from getting in those appliances and building nests that can cause major problems. IMO-- the #1 MOST important accessory that is a must have is a quality EMS or Electrical Management system like Progresive Industries. Don't just get a surge protector. They do NOT protect your expensive appliances from UNDER voltage which is more common than surges caused by a lightening strikes. I cannot tell you how many campgrounds we have been to that this device has shut down power to our TT because of under or over voltage. Also protects against reverse polarity, neutral ground and other common problems with campground pedestals. Look up Progressive Industries EMS on Amazon and read the hundreds of testimonials from customers on this device. Runs about $250 but a mere fraction of the cost of a new fridge, AC unit, microwave or TV.
About RV Newbies
