NemoScopes
Feb 25, 2015Explorer
Thank you Tatest for that info! After walking through some RVs this week I noticed how thin those walls are. But that is okay, I am sure I can manage something. Either by using a cabinet as you mentioned, or just setting up a station when not in movement. I may also just go with a smaller and lighter TV and that should help create some extra options.
Winter Sun, that is very pertinent information! thanks for the heads up. Adds weight to getting a smaller setup.
Busa Guy, dam you, I think you sparked my interest enough to start looking at the travel trailer and pick up truck prices lol. I don't know if that is a combination I want to go with since it seems like it would be hard to drive such a setup, but I may as well give it a look. I don't know if I can buy both a used truck and travel trailer for under $11,000 but I will check it out. Thank you for the suggestion, good to explore all options.
After doing some more RV browsing at my local RV dealer, and some additional thought, I may be steering away from the bigger Class A options. I was looking at the smaller 24'-26' Class C's at the dealership, and I actually really dug them. A very familiar feel, and since its just me in the RV, it seems like a cozy fit. The overhead cab storage would be fantastic for my larger surfboards too. Jeez, I can tell this search is going to take longer than I originally anticipated! Dang it! I really wanted to take a break from working and go on an adventure haha.
One additional question: When buying a used motorhome, what is the most mileage I should accept as okay. I was using under 90,000 miles as my limit. But can I extend that some? If I find a coach i really like, inspect it inside and out, test drive it, and finally take it to an RV mechanic to do a final check and it passes all those tests well, should the fact that it has over 100,000 miles still be an automatic disqualifier?
Thanks!
Thanks!
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
