Fla904
Jan 03, 2016Explorer
Colo Native wrote:Fla904 wrote:
So we're from Florida and passing through Colorado to get to Wyoming for a winter vacation, I've been told that the roads might be bad in Colorado and covered in ice/snow? Does anyone here have any experience passing through? Should I be concerned of the road conditions? Also do I need to add anything to the rv for the freezing temps? I have the fresh water tank filled up and do not use the water heater as I have the propane disconnected. So water only goes through the cold water tubes. Please let me know what I should do and if you have any advice. Thanks!
First which road are you taking? the roads maybe bad but that depends on which highway, I 70 through the mountains has a traction law and when in place if you get stuck you can be charged a fine of up to $600 if I remember correctly. You will have to winterize your RV and that includes draining all tanks and water heater and putting rv antifreeze in the water lines
We will be on highway 114, 371, 50, and 13. Will only be staying one night in co, is the antifreeze still necessary just for one night? Can I leave the fresh water tank and water pump alone? The tank is located under the bed as is the water pump.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
