My wife and I would like to try out a weekend RV (rental) trip to shenendoah in a few weeks but I am stymied by a few things: if there are no electrical hookups, does that mean no heat? I assume the...
You can have heat as well as the water system and refrig(battery power and propane) and even AC (if the generator is running). However no national parks allow you to run a gen. after about 8 PM and some areas not at all so the battery may discharge from running the furnace fan, lights and water pump. But sometimes you can make it through 1 or 2 nights fine, then recharge with the gen. the next morning.
