Bemota's avatar
Bemota
First Trailer
We got our first FW, 2011 Keystone Cougar. I have a bunch of questions:
Going to try snow birding, Just too cold in northern Minnesota any more!!!
What type of jack do you carry, or use TV jack?
How long will 2 12v batteries last, we had a slide-in, so we are frugal.
I fully don't understand all I don't know about the electrical system on this thing, the manual is no help, is there a wiring diagram out there some where?
After reading this site for a while, I plan on getting a surge protector, water filter, pressure gauge/regulator, tripod stabilizer, just to start.
I figured basic hand tools to carry with, anything else?
WE have been cleaning and fixing, can't say much for dealer prep.
The tires, I didn't notice on walk-through, were hideous, all the tread wore inside, had axels aligned, learned a lot from tech.
I re-drained all the water and flushed the system numerous times to get anti-freeze out of water heater and everything else. Fixed cable to truck connecter and brake wires.
Any suggestions would be greatly appreciated!!!
Thanks, Dan and Jan
  • In my opinion, the very first thing you need address & understand is the TT power distribution system. Find the Converter & share the make & model number with the Forum.
    There is no set answer to your question, "how long will my two 12-volt batteries last" But there is hope, if you understand the DC power supply & how to maintain it properly.
    Also, a very important factor concerns the type of camping you will be doing. Will you ever be Boondocking ?
    12 Volt Side of Life
    Read part #1 & 2
  • I don't know the answers to all your questions but my suggestion would be to read on this forum and others, read, read, read.
    Eight years ago I knew nothing about rving, but after reading all the material I could, learned enough to buy and begin. You will learn a lot from others experience.
    Have a great time!
