Old-Biscuit
May 01, 2015Explorer III
JohnG4706 wrote:
Thanks for the suggestions.
I went to Home Depot and bought some rabbit ears to check out the TV. TV worked fine. Got 2 stations...
I then took the wall plate off and checked the connections. Some were not screwed in all the way. Retested with the amplifier on and got 26 stations, some better than others. The rabbit ears go back to Home Depot.
I'm sure that the factory didn't check the outlet out with a TV.
Again, thanks.
When properly connected that ole crank-up antenna works pretty darn good.
About RV Newbies
