-Did you take your old Batwing out with you and test it on the same day and under the same conditions as you did the Jack: NO..
-Did you test your Jack with any VHF channels in the area?: NO, because there are two in the entire state of Il. Oh yeah... The Jack is so poor on VHF you wouldn't have seen them anyway. Just because there are no VHF channels around Chicago, don't assume thats the standard across the country because its not.
So the bottom line is that you don't really know do you? Had I not looked at the two antennas side by side on the same day and under 30 mins of each other I wouldn't have had a clue that they were that different. Just because you can now see 5 stations where before it was 2 means nothing because weather doesn't wait to change, and thats the biggest enemy of radio, especially in the midwest.
And for the "real world" comment, I can see stations 60 and 150 miles all the time at my "real world" camping spot, both UHF and VHF, and compare what I see with neighbors owning a Jack if I see one and am able to look. The 3 I have seen don't do nearly as well.
To your other comment. I bought the Jack to see how it compares to the Batwing and would have swapped them out in an instant had the two been even close, but they're not. I don't know what your interpenetration of "real world" is, but when the RV is parked at a random location and the antenna is raised to look for and stations and watch TV, that's as "real world" as it gets. The difference between your "real world test" and mine is that I also took $50k worth of gear to
back up and document what happened between the two antennas. And the numbers simply don't lie, regardless of ones definition of "real world".
So if you think your works for you, great
