jrp
Sep 02, 2014Explorer
Phydeauxman wrote:
I don't want to have DirecTV at home...would like to have it in the RV only. I am sure this is not going to work but thought I would ask anyway to see what others have done.
There is no reason it wont work, you just have to work through it one step at a time, and decide if its practical& affordable for your needs.
tens of thousands of RV's have DTV service. Most start out with DTV at home and take a receiver with them when they head out in the RV. if you don't have & don't want DTV at home, that's ok too, you just have to approach it a bit differently.
Yes, an RV account is similar to a home account, you pay the same monthly equipment/programming fees regardless of how much or how little you use it. There may be a way to temporarily suspend service for certain durations if you're not using the RV or the DTV service at all; or just cancel and reactivate next year, with extra fees. I've never been in that situation, but ask a DTV customer service rep.
Its a bit more frustrating dealing with an RV account because many of the DTV reps don't know anything about RV's. Many of their installers won't deal with RV installations. Unless you're a DIY type you'll need to find an independent DTV installer willing to work on RV systems.
All you need is an antenna, compatible receiver, an activated account, and be parked where your antenna has a clear view of the southern sky.
Things that can complicate it:
different types of RV antennas: dome type (SD only, no HD), roof mounted vs tripod type - setup/tear down each move, HD vs SD types, etc
local chans vs DNS national chans : with a mobile RV account you're entitled to get the network feeds (abc/cbs/nbc/fox) from either the east coast (NY) or west coast (LA); this requires mailing DTV a copy of your RV reg and a signed FCC waiver form agreeing that you will only use this recvr in a mobile vehicle/boat/truck. otherwise you're limited to the local chans spot feed depending on your actual location; and when you move to a new location (usually more than 150-200 miles) you call and have DTV change your service location if you want those locals.
the newer technologies that allow watching diff chans at the same time ; recording & watching diff chans, whole house DVR, etc are all things that add to the potential complexities in an RV installation.
About RV Newbies
