- steelpony5555ExplorerGet one of these frig fan It not only keeps the frost away but helps circulate the cold air all thru the frig. I would check your door seals and make sure it's not leaking somewhere. Just look for broken areas and then use a dollar bill, close the frig on it and see if you can pull it out. If the seal don't hold on to the dollar it may need replaced......
- tvman44ExplorerNormal, these fridges are not frost free. :) A 12 volt computer fan blowing on the fins greatly reduces this. :)
- Mandalay_ParrExplorer
Mandalay Parr wrote:
Turn the temp up one notch. Worked for me. Fridge is cold and freezer is even colder than before. Go figure.
When I said turn it up, that means temp up or warmer.
Jerry - 2012ColemanExplorer II
Mr_MrsSchlepprock250 wrote:
This is correct - however, it can work too good! If using one of these fans, don't set the fridge to cold, otherwise your veggies will freeze.
Our fridge used to do that. We bought one of the very small fans that run off of two "D" batteries and it hasn't done it since. It also helps the fridge stay cooler too by keeping the air circulated. - SultanGrisExplorer
Haha, i actually turned mine down, thought maybe it was too cold! Milk is too cold to chug. There is just a sensor clipped on one of the fins that slides up and down on the fin to adjust temp. Not sure how accurate that is, lol! - 2gypsies1Explorer III. . . or - turn it down for a few hours and it will defrost. Your food will stay cool enough if you don't open the door a lot. It is normal. You just have to fiddle around with it.
- Mandalay_ParrExplorerTurn the temp up one notch. Worked for me. Fridge is cold and freezer is even colder than before. Go figure.
- Mr_MrsSchlepproExplorerOur fridge used to do that. We bought one of the very small fans that run off of two "D" batteries and it hasn't done it since. It also helps the fridge stay cooler too by keeping the air circulated.
- sc3283Explorerperfectly normal
to lessen the amount of frost...dont let door open long when getting something from fridge
it will melt when you turn the fridge off
About RV Newbies
4,030 PostsLatest Activity: Mar 20, 2025
