JWRoberts wrote:
The bottom line is if it is level enough for you, then it's level enough for the fridge. I doubt seriously if not being level is your problem.
The OP first said -
"As of right now I have it parked in my yard, which isn't exactly level." and later followed that with -
"Ok if half bubble out is the max then I'm way off"."Way off" doesn't sound level enough for occupancy and therefore not good for the fridge considering we know that
any gas absorption fridge operated beyond leveling specs recommended by the manufacturer can begin to suffer damage to the cooling unit in as little as 15 minutes. If this rig has been sitting for days or weeks "way off" level with the fridge running then it shouldn't be any surprise at all that the cooling unit may already be partially blocked, as evidenced by poor cooling efficiency. :(
