cmsteele's avatar
cmsteele
Full-term travelling with an older RV
My husband and I are in the very early talks of planning a long-term (1-2 years) trip with our two young children and pets. I have a dream of buying an older trailer or motorhome, gutting, and totally renovating it. I'm wondering how good of an idea this is for long-term travel... Can it be done? Are there specific things we should look for/avoid in buying an older RV? Or are we just better off buying a newer one? Thanks for any advice!
  • How are your mechanical skills? Do you have access to a fully equipped wood working shop?
    Unless you can DIY it would be cost prohibitive.
  • DutchmenSport wrote:
    By the time you invest your time, effort, and money on an older RV, you may be better off just getting a new one and save yourself the time it will take to rebuild one and spend that time with your family. Besides, the rebuild could cost as much as newer one.
    Besides, when are you planning on this trip? If you plan 2 months to rebuild an older camper, you better re-think that. I promise you, your 2 month estimate will become 2 years of actual rebuild... if you have somewhere to get the camper under roof so you can do the work.
    X-2
  • By the time you invest your time, effort, and money on an older RV, you may be better off just getting a new one and save yourself the time it will take to rebuild one and spend that time with your family. Besides, the rebuild could cost as much as newer one.
  • DrewE's avatar
    DrewE
    Explorer III
    What are your parameters for "older" vs. "newer"? Are you thinking you'll be actually travelling a lot of the time on this trip, or will you more likely spend a week or two in one place and then move someplace else for a spell? (If it's traveling frequently, a motorhome has some distinct advantages--you have a lot more space and ready access to conveniences while on the road. If you're parked at a camp site most of the time, those advantages are much less important.)
    I think the most practical might be to by a (somewhat) older, good quality motorhome or trailer that does not need gutting and refurbishment and using that. At least to me, rennovation implies that the unit is in bad shape to begin with, which for RVs very often implies a good bit of water damage and a whole lot of work to bring it into decent shape. (If you merely mean redecorating, that's a little different matter altogether...but still start with a unit in good shape.)
    If you want to do a lot of customization or have neat ideas for a layout or something like that, it might be better to make a schoolie (school bus conversion) or similar. That's a lot of work, but you're at least starting with a solid vehicle structure.
    In either case, you're probably going to need at least several months of construction before setting out.
    Before doing much of anything, I would strongly suggest renting an RV for a week and seeing how RV travel works out for you in practice. It will also give you a better idea of some things to look for or avoid in units you're considering.
  • You can do a search of the forum and find a lot of great threads that talk about what to look for when you buy used, the costs involved and issues people have had. In general, renovating an old coach costs more than buying one that has already had the work done. But if you enjoy doing the work then it would be worth it to you. There are a lot more risks in purchasing an old motor home than a trailer because you have to worry about big ticket items , like the engine and the transmission, in a motor home. Take a look at past threads and I think you will find the information you are looking for.
