ky-newbie's avatar
ky-newbie
Furnace change (problem?)
Hi all,
I have a 2008 Keystone Springdale 249 FW, and the furnace operation has suddenly changed. It has a Duo-Therm thermostat which is turning the furnace off/on with no issues. The FW hasn't been moved since Sunday, and until yesterday, it seemed to work fine. I've been running the furnace for several weeks, as needed. I did refill a propane tank Saturday.
Here are the change details:
Today, I am getting a smell inside the FW that smells like exhaust. I've checked the outside ports, and they're clear. I can feel the exhaust coming out, with just as much volume as before. There is no wind to speak of.
The temperature coming out of the floor vents has dramatically increased. Previously, I could hold my hand over the vents without any problem. I just measured the air with a laser device, and it's 114 degrees. Holding my hand there for more than a few seconds is not possible.
Any ideas?
Thanks!
  • Yes, I installed a new smoke/CO monitor when I bought the RV this summer. I think I'm going to turn the furnace off, and use space heaters tonight. Hopefully, it's not that exchanger!! :E
  • What jumps to my mind is cracked heat exchanger. Do you have a carbon monoxide detector?
