Ozlander
May 25, 2013Explorer
skipnchar wrote:
It SOUNDS like you have the temp set to it's lowest but did not turn the SWITCH off that actually disables the furnace. Some models the switch is not easily seen (located under the thermostat) and when you push it find that it requires quite a lot of effort to move the switch. I had an old Terry FAn that was like that so I had to turn it off as DW couldn't make the switch move.
What Skip said. Our switch is hard to push off, you'd think you are going to break something before it snaps over.
The furnace being 12 v will have a fuse, not a breaker.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
