Jim-Linda wrote:
You "unplugged" the fridge to see if your attempt worked, i've not seen a fridge that had the 12vdc go to a "plug". Are you sure you did not unplug the 120vac? Usually the 12vdc power is connected to a terminal strip.
Jim
Hey Jim.
There is an outside access panel on the fridge side wall. Looks like it holds the fridge compressor and some wiring. There is an outlet in that access panel that has a cord plugged into it. ( just a regular black cord not unlike what is on a drill). Probably for for the compressor now that I think about it.
I'm learning as I go when it comes to owning my first RV and I have a lot to learn lol.
