bazaarsoft
May 01, 2013Explorer
Gas Grills?
Looking for suggestions on grills: what does everyone do? We're thinking of getting a propane grill that we can hook to the outside gas connection. If that's what everyone does, which grills are best?...
nohurry wrote:Ron3rd wrote:
That setup works fine if you have an external tank to connect to, then you're good to go. If you carry an extra 20 gal tank (or smaller) for bbq, it's fine.
Won't work with the quick disconnect fitting on trailers.
Yes, it will Ron. You have to take the regulator off the Q and get the adaptor, and hose. The RV tanks are already regulated, and can't run two regulators. The only down side of this is that if you use it elsewhere, you can't use the small portable tanks, you would have to have a re-fillable tank W/regulator, at home for instance. Not really a big deal.
