Tvov wrote:
Since we had the gen to use the A/C, it was running at full throttle. Found out that the vaunted "quiet" running of the Hondas is when they are on "eco" mode and basically only idling (charging camper battery and using fans, other light electrical loads). To run the A/C they have to be at full throttle. When running at full throttle, the Hondas are not as loud as an open "contractor" generator, but they are not quiet.
If you got the AC running with a 2000 watt generator, you were lucky. It usually takes two of them, especially if you want to use anything else.
