wa8yxm
Jun 10, 2016Explorer III
Only problem I had, one time, was technicial.. I will get to it.
In terms of other problems (People type or legal type) narry an issue
I DO USE A GEN-TURI if parked and running Generator for more than 30 minutes.. REASON: when RV was new 2 hours of Generator run time and the CO detector got very annoying (Which is what it is supposed to do by the way) Added the Gen-Turi and I could run 25 hours without a beep.
The one time: Well let me tell you about the Gen-Turi
One of those 25 hour runs I was in a city park, the Park "Ranger" (City official) ask how hot the thing got cause a child rubbing against it might get burnt.. I simply wrapped my hand around it and held it for a mintue or two.
That one time the Generator failed (As I said technical issue) The Gen-Turi was so hot, even after the generator shut down.. I could not handle it without gloves.. The Error Code on the Genny was "OVERHEAT".. No, not a problem with the Generator..l problem with the SUN.. It was HOT!!!!!!!!!!!!!!!!! out.
Generator was not down long, Soon as I moved the RV (Turned it around) genny worked again.
About RV Newbies
