charlie_good_ti
Sep 12, 2014Explorer
Agree !Use the truck stops---fresh fuel-much easier.Just pull in at pump than go inside an tell attentant how much you will need. They will want your credit card an will put say 200dollars available .Than when you are finished they will return to your credit card any amount you did not use.Most truck stops will not keep your card while you are fuelling but will need it again when finished fueling to credit your accaunt.Truckers do not need to do the above because they use a EFScard that allows them to fuel imediately as we do with autos.Also truckers will appreciate you pulling ahead after fuelling so truck behind you can start fuelling.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
