NanciL
Jun 14, 2016Explorer II
When I am putting gray water into my 25 gallon tote, I almost always have the same problem.
I simply lay the drain hose on the ground between the Trailer outlet and the tote inlet. Then when the hose is full, pick up the end near the outlet and raise it higher then the tote inlet. This will cause what is in the hose to flow into the tote.
Repeat it moving the raised portion toward the tote.
Once the amount that was in the hose is in the tote, repeat the process and just keep doing it until your tote is full.
A 42 gallon tote is way to big to handle !
Jack L
Jack L
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
