jktb's avatar
jktb
Waste water
I have a 2017 Jayco 5th wheel. Before departing the campground I open the black water valve, drain the tank then use the internal tank flush for 15 - 20 minutes. I then close the black and grey water valves, disconnect the hose and install the cap. There is no water draining from the sewer line and the tank indicators show empty tanks prior to putting on the cap.
Upon arrival at the next campground I set and level the trailer. When I remove the cap from the waste water hose line a few gallons of waste water gush out even though the black and grey water valves are still closed. This happens every trip.
Where could this water be coming from?
Thanks
