3oaks
Jun 14, 2016Explorer
SoundGuy wrote:That is the best solution and the first thing I thought of. Also solves the weight problem with the large tote.pdcostantino wrote:
Any suggestions on getting waste water to flow up hill into tote?
The obvious answer has already been offered - elevate the trailer. However, from your description that may mean elevating it quite a bit so an alternate solution, though costly, is to put that way too big, way too heavy tote tank in the back of your truck and pump waste (grey & black) into the tote with a FloJet Waste Macerator Pump. You'd then also no longer have to drag a heavy tote to hook it to the truck nor drag it to the dump station at "walking speed" but can simply drive your truck to the dump station with the tote in the back.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
