SoundGuy
Jun 14, 2016Explorer
DutchmenSport wrote:
The only way I have found to finish draiing the hose is to simply lift the hose a little at a time (nearest the tote), and let the hose begin to drain out. Then put the hose back to the ground again and let it fill back up, then lift the hose again. You may have repeat this a dozen times, but it will eventually drain the hose out.
I still find it difficult to believe so many still fool around with a heavy, expensive, hard to store tote tank and a stinky slinky when the alternate solution is SO easy, SO simple - a 12 vdc waste macerator pumping whatever you choose, grey or macerated black water, into your choice of container that's already sitting in the back of the truck. I happen to prefer 7 gal Aquatainers labeled for the purpose since when full I can still easily lower them for emptying into the dump station sewer inlet. They're also much easier to flush out than a tote and being cube shaped take up little space for storage. To each his/her own though but I do wonder why so many still struggle with the concept of a waste macerator pump. :h
About RV Newbies
4,032 PostsLatest Activity: Apr 29, 2013
