doxiemom11
Aug 11, 2016Explorer II
When you look at it, pretend you are using it. Can you sit on the toilet and close the door. Is the bed long enough. Stand in the shower - enough room to use it? Go thru what a routine might be to see if it works. Can you get to the bathroom when traveling, open the frig (no slides in the way). Won't matter as much if you don't plan on traveling far and it's for weekend use, but if you plan on full-timing or traveling long distances, then it will.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
