Bumpyroad wrote:
AlmostBoatless wrote:
Personally, having owned 3 boats I would search in CL for a used RIB - inflatable dingy - and make sure no patches - see lots of pics - there are plenty of RIBs out there b/c lots of us had to sell the big boat due to loss of jobs. They are easy inflated, easy to use and many are inexpensive! Search locally and good luck!
I question your "no patches" requirement. I had two small holes in mine that I used the factory patch kit on. these patches used exactly the same process/material that the boat was "glued" together with in the first place. my patches had exactly the same chance for failure as the original boat.
of course some folks here would recommend rejecting a motorhome because it has a tiny screw hole in the side 7 ft up. :s
bumpy
Duh - meant to say below the waterline!!!!! Guess I'm getting...well...older! I agree that a patch above the waterline will have no problems. Thanks for pointing that out!
